Cant wait to see to the pics Ted. Now hurry up mate!![]()
How easy was it to get to all the fasteners off?
I have the service manual which clearly states which fasteners need to be removed. Only the two in the wheel wells were any kind of challenge. The others just unscrew or pop up and remove.
The service manual assumes that the fenders have already been removed, so I removed the fender fastener in the wheel well just to make it a little easier to tuck the bumper edge under the fender.
All in all, a very straightforward job.
If anyone needs a scan of the relevant page from the manual, just let me know and I'll scan and post it.
Yes, those are the two that were a pain. I finally just put two flat blade screwdrivers under each and popped them out! I figured worst case, if they broke (they didn't), I could get new ones for a buck or two from the dealer. After removing them, I saw that the center shaft has ridges, but I don't think they are actually threads. I certainly couldn't get it to come out by unscrewing it. When I was ready to reinstall everything, I just pushed the center out, inserted the fastener into the hole, and pushed the center back in. Seems to be working fine!
I didn't remove the fenders or overfender trim. You're probably right - if I had, then getting to the back of the center pin would probably have been possible.
I did remove one of the pop up fasteners on the overfender trim to make it easier to get the wheel well portion of the bumper to slide back under it. Still not easy, but better than removing yet another piece of bodywork.
Here's the relevant page from the service manual.
The manual does assume that the fenders have been removed, so there is a little more to it once the bolts have been removed. You will need to use a little bit of force to unclip the bumper from the front fenders. They are just some kind of snap connnectors, so if you grab the inside of the wheel well and slowly but firmly pull outward, they will unsnap. I think there are three on each side.
How's it goin' everyone, I also purchased a grill, but I got the chrome mesh version. Installed it today, took me about 2.5 - 3 hours to install because it didn't come with instructions, so I had figure out on my own where to install certain brackets and what not. Bolted right over existing honeycomb stock grill. It looks pretty nice, I'll post pics later.
