I don't see it!Theres a clock button on the radio and you use the seek/skip buttons to change the hour/minutes.
I don't see it!
I hope I am not giving you wrong information but what I found in my Google search is that if you have the navigation unit, the clock / time is supposed to be adjusted or changed automatically by satellite and there is no way to manually change the time. If it does not cchange the time automatically you may need to have the unit replaced (which is very expensive). You might need to visit the dealer for more info.
Really?
That is right. It is with redNope, at least not in the 2014 I have. However, mine is changed with three buttons "H" "M" and ":00" dedicated to the clock. This could be different in the '07 you have, but I sincerely doubt it's set by GPS.
To clarify, we are talking about the red screen clock above the vents in the dash, that also tells you about HVAC and INFO. The GPS has it's own clock, but it uses it for calculating future trip times w/ traffic and arrival times when you set a destination.
NoThen does your dash have the buttons shown in the picture I posted above? If so, it's trivial to change the clock.
How to change clock or Time on 2007 mazda cx grand touring?
Tia
Changing time on dashboardare you chaning the time, or the DST function? both clock settings are in the nav menu. mine is set to automatic time setting, but I still have to manually go into the menu to turn on/off DST.
