cams help
mp3boy1984
low rid'n member
What kind of tools will i need to install my camshafts. I have both exhaust and intake cams. Like what specialty tools will i need, stuff that i can buy before i start the install....planning on doing it next week....so the sooner the help the better...thank you in advance
Same tools as you need for anything else.
Crowbar, Hammer, and Duct tape.
:D
Only thing I can think of that is special would be a torque wrench and a breaker bar large enough to turn the crankshaft.
At the bare minimum you should have some new cam seals, a nice set of socket wrenches, and a torque wrench.
You will need a Torque wrench for around 100-125 in lbs. You also need another for 37-40 ft. lbs. Socket set, Breaker Bar, Assembly Compound(Anti-seize) Black RTV(Gasket Silicon), New oil filter and oil(to change after you break them in), and new cam seals. Make sure you run the engine for 30 min at 1500-2000rpm to break them in. If you need anymore help or pointers pm me. I just did it last weekend so it's pretty fresh in my mind. Hope this helps! Evan
