Caliper Bolts: 1 Me: 0
Step 1: put closed end of wrench over bolt
Step 2: put hand over the closed end of the wrench to hold it in place.
Step 3: 3 lb sledge hammer. Repeat as necessary.
4. Step 4: Drive to hospital and have shattered hand repaired. :D
lol i found this out the bad way, well not as bad....it was the Caliper pin, an allen wrench, and a rubber mallet... lol
I put my mechanics gloves on after that...im now missing the skin on my index finger... doh!
Breaker Bars are definitely the way to go for getting caliper bolts loose. If you're going to use an impact gun, you better make sure you have the right extensions for it, and also, if you have a swivel bit or socket, it also helps. it also kinda helps if you turn the wheels. Of course, this method is usually the method I use on a hoist or something. If you're doing it via jackstands...good god, I don't know if I'd have the room to remove those bolts...
Similar Threads and Articles
