I keep hearing a kwick, kwick noise when I'm driving at low speed. (not touching the brake pedal.) The noise is coming from the back (rear left wheel)
The brakes are new since decembre 07 (pad and rotors). Since then, I'v changed the retainers (guide plates) on the rear left brake. I'v cleaned everything, I'v put some lube on the back of the pad that faces the piston. I'v lubricate the 2 caliper pins/sliders But I didn't lubricate the guide plates on the side that contacts the brake pads. When the mechanic did my brakes in december 07, he had a lot of troubles entering the piston (rear left) , but finally he got it and saved me from buying me a new one. Could it be my caliper/piston doesn't work correctly? Or is it possible the guide plates are touching my rotor?
