There is.....
How-To section
How-To section
samm5149 said:are you going to make plans for this...i think i would like to make this for my p5!
I think you have the same sub I do. Hmmm... You've indicated that you would not be willing - at this point at least - to make boxes for others. I for one would be VERY interested, either in a pre-built box (please?bratliff said:If for some reason I have to take it out, I will take some measurements for you. But I still would highly reccomend reading the fiberglass how to... You get more bang for your buck. I just felt more comfortable with the wood.
Basically the front board is 3/4" MDF the box sits up high enough to fit back in the hole where the jack goes. The sides taper out towards the front plate. The top tapers down to match the profile of the panel. The front steps out to gain just a little more air space. Also due to how small each of the panels were I used 1/2 MDF to help air space as well. Also ALOT of liquid nails..
Again you get much more air space for just as solid of an enclosure with fiberglass. So make sure you match your sub to your available air space.
