Boost Controler
falkofire
hey, as for my turbo, I am curious as to what type of boost controller u would all recomend and why? alright, help away turbo crew
I am not turbo yet, but
I have heard nothing but good things about the Blitz Boost Controller
machv_1693_2591583
You can find it cheaper at other places or sites.
Hope this helps
Or if you don't want to spend 400 bucks or more you can just get the Blitz street Spec boost controller you can pick it up for about 200 online and for the low boost we can run it is more than adequate. I ran it on my car when it was turbo and I loved it. It will hold up to 17 psi
So it will basically look like the one OurP5 shows? Can it sit inside the car or does it have to be under the hood?
Kooldino
It sits in the car which gives you constant control over the boost your turbo is producing. You can set it for strett use with a minimal amunt of boost or track use for however many pounds you want to run at the track, etc
