blueprotegelx
iZoom
- 2003 Mazda Protege LX-T
I was at a light today and then the car began to shutter real bad and i could hardly get it to budge into parking lot. Check engine light flashed continuously. I let car sit for a bit while I looked for any visible vacuum leaks as that is what it felt like--nothing! After letting it sit for a few and calling SER_Cyclops, I started the car back up and it was fine. AFR's were normal, Vac read 19-20 which has been normal since I boosted, and we drove car around for a few and it was fine. Check engine light was still on so I had it read:
P0300: Random/ Multiple cyclinder misfire detected
---I am assuming spark plugs possibly? I installed NGK 6's in July when I boosted. May be upgrade to 7's?
PO103: Mass or Volume Air Flow Circuit High Input
---Mass air flow? or Vac leak?
Suggestions please? I did a search and these are some of the responses I have found.
