hyperboarder
- 2002 MP5
daedalus said:I'm upgrading my MC to the 929 Unit for the Wilwood 6 Pistons.... Why not... it cant hurt, and i'm sure the brakes would make use of it.
How hard/expensive is that mod? (the MC)
hyperboarder said:How hard/expensive is that mod? (the MC)
All of the ideas posted here are very interesting but before spending big $$$ I would suggest you try more aggressive pads and one of the different fluids suggested. If that doesn't do enough, you could add cooling ducts to get even more low $ performance. SCCA racers in SS and IT classes have to stay with the stock rotors and calipers and do fairly well changing only the pads and fluid and (of course) tires.yellerandahalf said:I mean I'm experiencing brake fade. Whether it's pad fade or boiling fluid I do not know. I am running carbotech bobcats on all 4 corners on the street (which is where the most recent fade has occurred, on an AWESOME section of downhill). I run bobcats on the rear and panther plus on the track, but haven't been back since I've got the new power. However, on challenging sections of road, I have experienced fade where I did not before, even at a measly 11psi (run 16psi on track).
