Better A/S rubber
I'm not entirely impressed with the Toyo's. I have Continental DWS's on my daily and I have thoroughly enjoyed each mile on them. Problem is, the sizing of the wheel on the GT wheels. You guys have any insight?
Very few tires are available in the 19" size that comes on the GT models. However, the Pirelli Cinturato P7 tires should be considered. They have higher ratings on TireRack.com and they're also a lot less expensive than the OEM Toyo tires.
I went with 18 in aftermarket rims and purchased the Continental DWS as well. I can't wait to use them in the snow this winter. Plus, they're rated for 70k miles! (which seems unimaginable to me)
I did the same! I think the sidewall of the Continental DWS is a bit too soft for my liking though...
I had Conti DW (no S needed in FL) on my last car and they handled amazing in the wet. They were so/so in the dry, but coming from the runflats the car had come with they were a massive improvement.
Switch to 17" or 18" wheels. You'll probably pay your aftermarket wheels off with the greater selection of rubber and better deals.
Anyone that has gone with a wider tire, but stayed with a 55-series, can you share your ride impact?
You're technically now running a taller sidewall, and should have ever-so-slightly impacted your speedo. I was thinking a 235/50 might have been the more obvious choice.
From my experience, Michelin Super Sport are probably the best combo of ride and handling for dry and wet.
We have it on our BMWs and Porsches. I upgrade our CX-5 wheels to 20" and they didn't have the Michelins in the size I wanted so the rep recommended Kuhmo's Ecsta 4X with siping and they have perform really well.
If you are referring to the Michelin Pilot Super Sport range (I run them on my M3)? There is little point on running such a tyre on a CX-5. The CX-5 has neither the engine, chassis or braking performance to warrant such a tyre.
LOL... Good point but I personally don't agree.
Michelins are standard equipment on higher performing cars than my Porsche's and BMWs - but does it mean its not good enough for them either?
Tires are one of the most important aspects of the driving experience and safety, regardless the value of the car and performance potential.
For whatever its worth...
My wife's '11 328XiT and my '11 M3 (E93) vert has run flats and its horrible ride. I swapped them out for Michelins and its transformed both cars in every aspect. Specifically my M3 is not a pure sports car but more of a GT - in my opinion, its too heavy and big to be real true sports car. The run flats made the M3 ride very choppy at times and turn-in/exit out of corners at higher speed felt unstable. So when I swapped out the run flats, all aspects of the handling was much improved, especially not so smooth roads.
I do not understand your 1st sentence.
Tyres are 'the' most important safety feature of a car after the driver but that has little to do with putting on performance tyres on a non-performance vehicle. The benefits that the Michelin Pilot Super Sport tyre brings will not be used by the CX-5. It is overkill and adds little value in daily use. The tyre was developed in conjunction with BMW M and Ferrari. BMW recommend it for the M3, M5 and M6.
M3s do not use run flat tyres, they always have and continue to use, normal tyres. There are only a few BMW approved tyres for the E9X M3 and none of them are run flats.
But on my Bugatti Veyron, the tires are blah blah. And on my Ferrari F430, the tires are blah blah blah.
Seriously, kids. Stop it.
Maybe not for UK but here in the states, my M3 and 328/335's were on Bridgestone RFTs, not normal tires...
But who cares? Its a personal choice whether someone wants higher performing tires vs factory.
