AWR rear mount
First you need to remove the plastic bracket that holds the wire loom that passes there.. You have two M6s that hold them in place... You have to break the lower one and get working on the rear motor mount..
You should use a jack and a wood plate to sustain your motor and to be able to align the holes when putting your motor mount back in.
You need extensions, patience and beer ;)
