Yup, this mod is great! I too noticed having my music with bass on made the alarm "honk" until the TT shut the car off.noclue119 said:some one going to do a how to and stick it in the how to section?
SoniCraze said:rofl..2day at lunch i get out of my car, 40sec countdown begins, i lock/arm then go inside..
as soon as i get inside i hear a honk...look oustide, car looks fine, then another, and another.....im like wtf? turns out it was the music settin it off.
Anyone have an answer to this? I'm going to try this mod just want to make sure beforehand. ThanksWiggles6983 said:Ok if you do this, say somepne breaks into your car while the engine is off and the alarm is going off, does it still kill the starter so they can't as easily drive away with it? (really simple to test, just sit in the car with the TT running the engine, arm the alarm, let the TT shut the engine off, then open your door to set the alarm off and try to start the car) Also, is there a way for the alarm to kill the engine while the tt is running it if the alarms goes off?
does that mean that cutting those wires would get rid of the starter kill or something like that ?jurgs01 said:The wires that kill the starter are the two larger guage wires going to your alarm module via the smaller plug
Don't worry about it. The starter kill is the 2 wires that are alone on one plug. If they cut those wires they wouldn't be able to start your car (if you have any doubts unplug those wires from your alarm box and try and start your car, it won't work). When your alarm is set off your ignition is disarmed, and the only way to enable the starter is by reseting the alarm box (like pushing unlock or lock on your keychain). What those wires do is complete a circuit to your starter. If the alarm is set off they break that circuit. Cutting them would break that circuit as well. Like you said, if someone really wants to steal your car there is always a way. Most average criminals are looking for the easy way to do it (I imagine most don't even have a basic knowledge of electrical principal that's just something you see on the movies), and if they see a deterrant they go to an easier target. Oh, and those wires aren't the wires you cut to allow you to arm your alarm (orange wire pin 6 completely different). That wire just tells your alarm whether your starter is in the on position, and has nothing to do with the circuit to the starter.Metal MP5 said:does that mean that cutting those wires would get rid of the starter kill or something like that ?
i'm just a little concerned with the fact that the alarm system diagram is printed on the box =\ but like i said, i dont really know how these things work. maybe having the diagram on the box doesnt change anything ?
help =)
