Are CX-5 and CX-50 brake components interchangeable?
N7turbo
2023 CX-5 2.5T ... 2024 MX-5 RF GT
I don't expect anyone to definitively know this, but I wonder if the power brake booster or master cylinder could be swapped from a CX-50 to resolve people's CX-5 soft brake pedal complaints.
I don't notice much (if any) difference between the 'softness' of our CX-5 vs CX-50. Also, people complain about the CX-50 brakes too, so I doubt that swapping anything other than changing the pads themselves (with aftermarket), will make an appreciable difference.
Personally, I like the 'softer' travel in the brakes - it gives me more control, especially when coming to a gentle stop.
A common way to firm up brakes is to swap the brake hoses to each wheel with stainless steel braided lines. SS brake lines are less than $150/set.
I did this on my 2500 pick up. The brakes went from soft to very firm. A lot of the soft pedal are the brake hoses expanding under pressure. A quick look, I didn't find a supplier who sells SS lines for CX 5s.
We use SS braided brake lines on our race cars for reliability and firm brake pedal.
I might change to SS braided hoses later this year when we do a brake fluid flush.
Here is a link showing SS braided lines but don't fit my CX 5, only for reference. I have contacted this company and asked for a quote.
https://www.buybrakes.com/techna-fi...t-for-mazda-cx-5-front-and-rear-4-brake-lines
I bought my truck SS brake lines from Crown Performance. Easy guys to deal with and do what they say. I've contacted Crown as well.
https://www.crownperformance.com/stainless-steel-brake-line-kits/
They are significantly different. Neither are perfect. Ideally we'd have something in between the two. A little firmness from the CX-50 (but not as firm) and without the delay from the CX-5 brakes. Overall, I prefer the CX-5 brakes, but I don't prefer the delay.
I think the MX-5 does it better.
New brake hoses last year (and naturally new fluid) firmed up the brakes nicely on my 2014. New pads followed shortly thereafter but it was the new hoses and fluid that made the improvement.
Good to see this helps!
Rubber hoses get soft with age. The expand when appying brade pressure. Sometimes a hose collapses and causes brake shoes to drag. SS braided brake lines is a common upgrade on my +20 year old 2500 pickup. Stopping a 9,000 pound truck with a 15,000 pound trailer NEED excellent brakes.
Crown Performance asked for my vin so he can look up the brake hose drawings. I'll buy a set of braided SS hoses and have them on them ready to go when I flush the brake system in 2026.
This thread got me motivated to swap out to a Performance brake hose. They will complement the drilled and slotted front rotors!
Would this explain why the CX-50 has a firmer brake pedal? I doubt it—I'm pretty sure they would use the same kind of lines in all of their vehicles. So what else would it be besides the brake booster? I would like to see someone take a closer look at that.
Interesting that you mention changing the pads. I was thinking the same and maybe a grippier pad requiring less braking effort would help.
X2 pads will make a difference as well.
Before we had 5k mi on our CX 5 I swapped put front brakes pads and for fun drilled and slotted rotors. The OEM pads squeaked and produced a lot of brake dust.
These pads don't squeak or dust like the OEMs. Slotted rotors grip the pad better as well. Both may have improved soft brake pedal. I don't remember feeling a difference.
I just started the car and applied brakes. Pedal went down several inches and was firm. I'll observe driving.
I believe the tubos have CX 90 front brake parts. Pad and rotors are different than NA. With slotted rotors it will put your nose to the windshield.
Still, I'll swap out the rubber brake hoses for braided SS. These were a nice upgrade on my truck.
Generic pic.
OK, so I'm stepping back a little from my statement above...
Last night I had occasion to drive the wife's CX-5 again. What I DID notice as a difference to my CX-50, was that the initial 'bite' of the brakes was an appreciable way down the brake travel from that in the -50. Once the brakes started to bite, they acted about the same between the cars. Not sure why or what could cause it, but that initial brake travel was the only difference I could feel.
Exactly. That's the delay I'm referring to and where I think most users complain. I've gotten used to it over the years (I've been driving CX-5's since 2014) but I definitely notice it affects my stopping distance, as I don't come to the gradual stop I would like, but rather begin a little late.
I'm not convinced that it's pad grip; it feels like there is lag from the time you push the pedal to the time they actuate. I could maybe see hard lines helping with that, but maybe a stronger brake booster is what is needed. Just my thinking.
SS Braided hoses help the brakes react faster.
I need to find the brake pedal and master cylinder drawings to compare 5 to 50. The delay could be in the pedal to master cylinder linkage. I'll take a look in a few days.
Yesterday I observed our CX 5 and paid close attention to how far the brake pedal depressed before slowing the car. Gee, I couldn't find any fault with how far the pedal depressed or how quickly the brakes responded. The pedal feels soft like other cars with rubber brake hoses.
As mentioned in this thread we have drilled and slotted rotors and R1 Concepts pads. When needed, this car stops on a dime. Panic reaction has always been acceptable.
I'm still waiting for a response on a custom set of SS braided brake hoses. I'm loving these on my 2500 series pick up truck. The pedal response on this truck is night and day difference with SS braided brake hoses.
IF the price is reasonable, I'll install a set on the CX 5 for a fast response brake system. I hope my wife adjusts!!!!
I also drive a 2024 Miata and have driven two 2023 CX-50s. The delay/softness is not there and they are all using the same rubber hoses, I am certain.
Have you bled your CX 5 brake system? Maybe some air was not removed during assembly. When I experience a soft brake pedal, I bleed the brakes. It's possible, not likely, but possible the system has some trapped air in the system. OR worse, Mazda didn't prep the master cylinder and it has trapped air. This is would the first area I would check. Bleeding brakes is a low tech procedure. Brake fluid is cheap.
To my surprise, I found the transfer case and differential fluid UNDER filled! It appeared to be about 70% filled. Maybe in their rush to ramp up production not all the air was removed.
We are satisfied with our 24 CX 5 brakes. I'll be changing brake fluid mid 26. If I notice air bubbles or notice a difference, I'll reply to this thread.
I haven't but it shouldn't be necessary; I made this post because there are countless threads and posts about CX-5 brakes being soft. I am personally used to it having driven them for many years. My 2017, 2020, and 2023 were all the same. But I think they could be improved. This is just part of the way that the 2nd gen CX-5 is. It wouldn't surprise me if the Mazda 6 is the same.
So folks are complaining and not working on solving or improving the issue...???
My Dodge 2500 had very soft brakes. I replaced the hydro boost
This helped alot. The hydro boost seals and shafts were worn.
Next I changed the 18 year old brake hoses to rubber. Firmer brakes.
Lastly changed out the new rubber brake hoses to braided SS. Now they are rock hard.
I also went on a caliper dragging brake pads campaign. I'd stop and shoot my brake rotor with an infrared gun. I fixed those too.
Fast forward to our 2024 CX 5, dusting and squealing oem front pads. I replaced them and up graded the rotors. 5k mi on them. Yes they were substandard, I just fixed the issue and move forward.
Added a turning Vane in the intake and bleed in damper based on engine load. Fixed two more flaws. Improved the ground system and several other flaws.
Got a tune to uncork the turbo and improve FE. Improved the Socker Mom suspension.
The point, I didn't complain or shoot down others ideas. I took action, even though I shouldn't have to do any of these items. The end product suits our life style.
Last summer my 19 year old, 275k mi truck averaged 30 mpg hand Calculated on two planned routes. Probably the best in its class by far. That was an increase from 18 mpg new. Brakes were one piece of the puzzle.
I'll get a set of braided SS brake hoses and firm up the brakes and report back either way, positive or no change.
I hope others take get into action and we figure a solution. Who knows, Mazda might copy our solution. They are the most detailed car company I've seen.
How did you improve the ground system? Added some bonding straps? Could you share some info on this? Maybe pictures? I'm thinking about adding some too.
I would also be interested, mainly in grounding locations and AWG.
