They are significantly different. Neither are perfect. Ideally we'd have something in between the two. A little firmness from the CX-50 (but not as firm) and without the delay from the CX-5 brakes. Overall, I prefer the CX-5 brakes, but I don't prefer the delay.I don't notice much (if any) difference between the 'softness' of our CX-5 vs CX-50. Also, people complain about the CX-50 brakes too,
New brake hoses last year (and naturally new fluid) firmed up the brakes nicely on my 2014. New pads followed shortly thereafter but it was the new hoses and fluid that made the improvement.A common way to firm up brakes is to swap the brake hoses to each wheel with stainless steel braided lines. SS brake lines are less than $150/set.
I did this on my 2500 pick up. The brakes went from soft to very firm. A lot of the soft pedal are the brake hoses expanding under pressure. A quick look, I didn't find a supplier who sells SS lines for CX 5s.
We use SS braided brake lines on our race cars for reliability and firm brake pedal.
I might change to SS braided hoses later this year when we do a brake fluid flush.
Here is a link showing SS braided lines but don't fit my CX 5, only for reference. I have contacted this company and asked for a quote.
https://www.buybrakes.com/techna-fi...t-for-mazda-cx-5-front-and-rear-4-brake-lines
I bought my truck SS brake lines from Crown Performance. Easy guys to deal with and do what they say. I've contacted Crown as well.
https://www.crownperformance.com/stainless-steel-brake-line-kits/
Good to see this helps!New brake hoses last year (and naturally new fluid) firmed up the brakes nicely on my 2014. New pads followed shortly thereafter but it was the new hoses and fluid that made the improvement.
Would this explain why the CX-50 has a firmer brake pedal? I doubt it—I'm pretty sure they would use the same kind of lines in all of their vehicles. So what else would it be besides the brake booster? I would like to see someone take a closer look at that.New brake hoses last year (and naturally new fluid) firmed up the brakes nicely on my 2014. New pads followed shortly thereafter but it was the new hoses and fluid that made the improvement.
Interesting that you mention changing the pads. I was thinking the same and maybe a grippier pad requiring less braking effort would help.I don't notice much (if any) difference between the 'softness' of our CX-5 vs CX-50. Also, people complain about the CX-50 brakes too, so I doubt that swapping anything other than changing the pads themselves (with aftermarket), will make an appreciable difference.
Personally, I like the 'softer' travel in the brakes - it gives me more control, especially when coming to a gentle stop.
X2 pads will make a difference as well.Interesting that you mention changing the pads. I was thinking the same and maybe a grippier pad requiring less braking effort would help.
OK, so I'm stepping back a little from my statement above...I don't notice much (if any) difference between the 'softness' of our CX-5 vs CX-50.
SS Braided hoses help the brakes react faster.OK, so I'm stepping back a little from my statement above...
Last night I had occasion to drive the wife's CX-5 again. What I DID notice as a difference to my CX-50, was that the initial 'bite' of the brakes was an appreciable way down the brake travel from that in the -50. Once the brakes started to bite, they acted about the same between the cars. Not sure why or what could cause it, but that initial brake travel was the only difference I could feel.
