MSPDetroit
- 03 MSP Black Mica
how much more are the gain differentials in the catless than w/the hi-flow??
not sure on the exact gains from single cat to catless but it will be better. but you will not be emissions freindly and if you get cought you can be fined. i think here in nj its a $10,000 fine.MSPDetroit said:how much more are the gain differentials in the catless than w/the hi-flow??
damn, i tried to sneak my way outta that by just telling him how it workedjersey_emt said:MIL = Malfunction Indicator Lamp, it's another name for the CEL.
The product is called the "MIL Eliminator"
Hey prospeed I saw you have the Apex down pipe with the cat. Have you had any emissions problems with that? Do you have to take it off and put your stock downpipe on to pass emissions?not sure on the exact gains from single cat to catless but it will be better. but you will not be emissions freindly and if you get cought you can be fined. i think here in nj its a $10,000 fine.
hayula said:what u can drive around catless in VA??
How much is high, someday day I would like to boost around 13-14, is it still worth going to the 3", and will the performance gains still be around the 10-12whp (stock boost) range with the 3" or is there the posibility of more.mx3ownzj00 said:unless you're going for high boost pressures a 2.5 is fine.
