Alternator Light Flickering On/Off (99 626 LX 2L)
bobnsofi
Hi all,
weird electrical problem
battery light flickers on & off
I cleaned all connections to the battery, alternator, and neg grounds to the engine & bady
1999 626 2.5L LX automatic
any other ideas from you pros????
thanks in advance!!!!!!!!!!
If you have a volt Meter check the voltage on the battery, if its getting a bad voltage it could be your alternator, also check the voltage on your alternator. A normal voltage is 12 or above. I hope you get it her fixed.
