Airflow Logistics AFC dyno results
ok, so a question i have is, say you run the 10 psi map, do you need a boost controller to set it at that or does running the map put the psi up that high?
Sorry don't know about these kind of things.
so would this software run ok on windows XP?
and would it be fine to run a serial to usb converter cable?
just wondering if the GB will be posted in the MSP vendor's section, or the General Vendor's section? Or if you could post a link to it when it happens on this thread, that would be good too. Thanks.
it will be in the MSP vendor section...should be up by 10pm tonight....I'm actually out attempting to find a wholesaler for a possible wideband o2 package today so I wont be getting back to the comp till around 5ish.....
Is there a chance we could see a wiring diagram so we can know exaclty how it works? Does it just inturupt the MAF signal just like the Emanage? If so, I'm interested.
Will this rid my car of the "long term fuel trim storage" that lets the car get progressively richer as the weeks go by? I get really tired of resetting my computer every two weeks. Right now I'm getting on average of 230 miles to a tank, After I reset I get 315 or so for one tank than it's back in the low 200s.
If so, do you take credit cards not through Paypal?
Britt
Ok boys and girls GB is up!!!!!! On the wiring question...3 wires for powering the unit, maf sig in and maf sig out wires, o2 in and o2 out wires...so a total of 7 wires to splice in...when i get back on later tonight I'll type up a little more informative wiring explanation...
So, could a wideband sensor be used in place of the stock O2, or they would have to be in conjunction?
DSM Convert, The o2 in and out wires for the first o2 sensor right? (not the 2nd one that is eliminated by the catless pipe?)
Is there anyway of turning this unit off once it is installed cuz i might need it to be off for auto-xing
