Aftermarket Head Unit questions
Rotus8 said:
That will inflate your MPG numbers by quite a bit. The tank is 14.5 and points to empty at about 12.5; a big error. You need to divide by the amount off the pump.
If you do it my way it deflates your mpg actually. Say you go 320 miles and you fill right on the empty line which should be 12.5, my way you get about 22mpg (320/14.5), if you do it your way which IS the right way you get 25.6(320/12.5).
I'm gonna do it your way now since that should be dead accurate if it really is 12.5 at the empty line. Thanks for the lesson!
khaydin said:
I took another picture today so you can see what both LCD's look like when the car is on. I still have to use the AUX jack on this headunit also because the stupid iPod connector is back ordered :(
Thanks for the image... works for me. Post again when you have installed the steering wheel controls.. I am gunning to have everything working the way it did stock, but with a better audio/visual setup.
