got it. afr is in the high 13s warming up now. i tried to make it a bit leaner but the car would stall out
I thing I'm using a modified version of your 440 map.
Running good but idle is lean. Like 17-18. I just changed the coils, wires, plugs, injectors-to 440s, not sure what else to look at.
Nice.
The settings are @10
I have a grounding kit. I'll try and clean and test the o2 sensors. Thanks.
Pm me if you have any more ideas.
If I were to run a map with all 10s should I expect the car to run like there was no afc installed or is it still going to have some influence? I'm trying to figure out if my unit is working correctly and thought this might be easier than actually uninstalling it. Any input?
