well I just did a little tuning yesterday, I got the WOT full boost set up ok, I did notice though that when I have the laptop hooked up, the afr's are slightly higher than when it is not, and sometimes on my log maps there is a random dropped in everything (the lines) which makes me think, since I can't feel anything in the car, that it is electrical.. so my plan is to solder the wires, and I know I should have done that first, but I didn't really have time when I did the install... and hopefully that will also help with the drop in afr ratio after disconnecting the comp. because I tune it great, then I disconnect and do a test, and it's pretty much always a little richer, I tune conservatively, like around 11.5ish and drop down to 11 by 6k-6.5k rpm, just wondering if anyone else has had this issue ever..
also I noticed that when I did a disk compact (an option under the File section of R4 software, I made a copy of the file before doing it,) but it deletes all the extra crap from rewriting all the maps and stuff, but anyways I noticed a GREAT improvement of idle after that, I think the clean load of the tuned map really helped it out, so I suggest everyone to try this if they have not done so already..
I just need to tune for the low boost throughout the rpm band because I notice like on highway driving or daily driving when I don't go full boost, I just stay around 2-5psi before shifting, that the afr is craaazzyy rich, and I stumble and hit fuel cut sometimes, which I am guessing is because no one has ever really tuned for the lower psi for the full rpm band, at least on the stock supermap, so that might be some of the hesitation and stumbling and complete crappy driving that some people have experienced, once I get some time I will do that and load the map, I'm working on tuning it around 75-80* outside... with an upgraded smic, then I get my FMIC at the end of this week and have to get the install done on that, then see how the tune works for that lol
