Ricktalife
- 2012 Subaru WRX
stock turbo? If so, you would definitely not be maxing the injectors at 8psi.
yes, stock turbo, I figured asking if I was maxing the injectors was probably a dumb question at that level haha.
SpeedAdiction: thanks for the info, I've tried what I think is what you are talking about, I know I need more practice and familiarity with the ssafc though.
I'm pretty happy with my map at low rpms and part throttle, almost no matter what it seems to lean out around 4000rpm when I really get on it though, is there a ratio that I need to worry about as far as increasing fuel? It seems better to slowly increase fuel, instead of just jumping from 10 to 10.5 I should work my way up right or is that not necessary or is this really one of those theres no consistent answer it depends on your setup things?
I'll try to get a map and or log up soon, I don't have the computer I use to tune at the moment.
^^Also, he is not trying to insult your intelligence but it is a very catastrophic mistake haha.
yea, I got it, you guys seems to be a good crowd haha. I guess I wasn't clear, I was referring to the numbers in the ssafc map, not AF ratio.
anyone have a decent map for a 28rs w/ walbro, 440s, TBE, FMIC,...?
hit me up please
I put the links to all the maps on the first post
my biggest suggestion at this point would be to make a few of the data logs and upload your map with the runs on there so we can look at them and whats going on better. that would help a lot
