Ricktalife
- 2012 Subaru WRX
I'll try that thanks.
Bandar I would definitely try out Jays summer map, it is perfectly safe to run I tested it myself with my FMIC. Only downside I've noticed is that the AFR's are a little wacky when you first turn the car on, but 1 or 2 throttle blips will even it out. It seems like a nice base map.
So i was comparing ur tune to the superstockmap. So the lower u go the leaner the system gets? like, 9.7->9.6->9.5. Im thinking i might try ur summer tune. Its pretty straight forward.
So i tried his map and the car runs good. Healthy strong. Only thing i notice is that from a stop and u gun it i get lots of hesitation everytime i shift. Also, I still get a really rich reading at WOT. But this tune is by far the best i have tried out. I just need a little tweaks and itll be good. I didnt have the idle issue tho.
Well this thread is for the Split Second Air/Fuel controller. There is a version with timing capabilities but it is not really mentioned that much in this thread. Also, most if not all of the maps posted on here are just base maps with a simple tune, so you can take them and suit them to your own needs.
gotcha I have the FTC1 (Does timing)... Even though these are base maps I don't understand how idle can be anywhere near where it should be unless there is somewhere you can input your injector size?
ya, howd you work out Split Second AFC tuning with Apexi AFC?.. but ya ditto what Rictalife said
EDIT: saw your post before I posted it, lol but ya larger injectors for the MSP during idle and stuff doesn't run that well from what I have seen from my brother's car (but he also has the high flow fuel rail so maybe that might have to do with something) but from all the people that have them, the 440cc injectors on stock ecu out of boost isn't that big of a difference for the ECU to control, I dono how it does it, but it just regulates it well enough for the change in injectors
I think that the reason you don't have to tune at idle is because the car stays in closed loop. It monitors the narrow band O2 sensor and adjust the long and short term fuel trim (injector pulse width) until the O2 reading is in the desired range. In other words the factory ECU will learn the proper idle as long as you don't go too crazy with the injector size.
