Edit.. oops I guess I did post it already lol, just was posted after a few sec later.. but anyways
I would search through pages 50-60 about, we go into pretty good depth about what the maps do and how it works and how changing this or that will affect the afrs and stuff.. but for starters, I would suggest changing your "over pressure" to 0 or .5 or if you want a lot of people do -1, I personally believe that it helps bring the maps from closed into open loop a little faster in boost, but also, for data logging go to AUX input or output I forget, but the values should be 10 and 2 if you have the AEM wideband for the values a and b I think it is...um I would reliable AUX A as AFR or something like that just so it's easy.. do 3rd gear runs, do several at a time before changing anything, and only change things that are somewhat consistent between the runs you do. and make sure you do very small changes at a time... there is an option there to "change value by" it is a % change, so change value by 1 or -1 will change it by .1, also I think I mentioned this above, when your car is at rpm 3.4k rpm for example, and 6.7 psi, the cell value the map will use is 3.5k rpm and 7psi, it rounds up pretty much, so make sure you know which cells you are changing and the range you want to change before you actually change it.. other than that, just take your time, and look around those pages I suggested before.. it might start around page 40 instead of 50.. but it is where I start posting a lot and there are a lot of these similar topics posted there
oh, should be obvious but never know.. sometimes your laptop will think the connection (if it is usb) is a mouse, if it does this, make sure your comp. is on before you plug into the ssafc, and if it happens to make your mouse bounce all around, just disconnect and connect a few times till it works, have the program open sometimes helps too, also car should be off, but if you turn it all the way on it sometimes helps connect, just turn off once it is connected to the "on" position.. I think that is about it, all of this and more was covered in the pages like I said b4.. I asked a lot of questions when I started out lol so its all covered.. hidden
