So recently my ac stopped blowing in the front, however it works perfect in the back, cold as ice! Any ideas what it could be? Anyone have or had the same issue?
Check the blower motor for power and ground with the system set at a high fan speed. It's located in the passenger foot well area and is relatively easy to access. If it's getting proper power and the ground is good then it's likely dead. To verify you can 'jump' the motor by attaching jumper wires to give it power (assuming the ground is good).
It's a fairly easy part to swap out if it is indeed the issue.
