Hello All,
New member on this site and I am hoping you can give me some help on a perplexing problem. I've worked on cars for decades but am a little new to A/C work. A while ago, my A/C compressor locked up and I replaced it with a UAC kit (compressor, condenser, drier and expansion valve). I have the Mazda Service Manual and I replaced the components as dictated by the procedures in the manual. A/C lines were flushed and blown dry, new seals installed, AC oil came in the correct amount in the new compressor, and system evacuated to 28mmHG and charged to 24PSI Low, 250PSI High (near 100F degree temps) at 1500 RPM. As far as I can tell the 22PSI is about 95F degrees per the manual and I was definitely hotter than that. Hard to read the graph in the manual, but graph goes higher than 22 at near 100F degree temps.
Problem is, I can only get about 70F degrees at the AC ventilation ports. All temps, etc. taken while car is in the driveway with the radiator fan running.
Driving it, I can get the AC vent temp down to about 65, but no more.
I am thinking that one of the new components is faulty and leaning towards either the compressor or expansion valve.
Anyone experience something like this or have an idea of where to look for the issue?
Thanks in advance.
Car is 2006 Mazda 3 S A/T
Thanks in advance.
