OK, so you are saying that it is easier to squeeze more hp out of an already high HP motor that is near maxed out than it is to get it out of a highly detuned motor that is nowhere near it's peak potential? AGAIN- WTF is so hard to understand that YES, the ECU is untweakable (right now
) and YES, it is so god damn rich, it should be considered a pollution risk BUT- At the same time, if it is dumping XXX fuel regardelss of airflow, how is increasing the airflow NOT helping the Air/Fuel mixture??? Instead of pulling fuel electronically though, you are adding air mechanically... Arrgggghhh...... (bang) (bang) (bang) I picked this car to mod because I saw you guys needed help and I thought you, in return, were capable of being helped... Maybe I should have picked a car with a more knowledgeable following so I wouldn't have to deal with it. No offense to those of you out there who are knowledgeable or those who seek to LEARN something....
Joe
PS- How many 557 whp LT1 Z28's have you built, 487 whp Talons, 414 whp Jetta's, and a whole s*** load of tuned STOCK (aside from exhaust, air filter and boost) DSM's putting out 250 whp and up to base your knowledge on? I know the Z28 isn't comparable, but just proving I have been there, done that... You???
Joe
1st MP3 in NH said:Less boost is only relitive to the volume of air being moved not to mention we aren't a high compression engine, only 9:1.
If this was an S2000 with a T4 these numbers would be believable. However!
ITS A GOD DAMN PROTEGE WITH A TOTALY UNTWEAKABLE ECU, A TINY TURBO CHARGE AND AVERAGE COMPRESSION!
NOT TO MENTION ONLY 140 WHP STOCK!
77 would be very believable on a car already throwing 250whp but not 140. YOU CAN NOT GET A 50% INCREASE IN HORSEPOWER FROM AN EXHUAST, INTAKE AND 2 PSI.
Not in this world or any other!
We have no dyno to prove anything!
There was never a baseline done on the dyno!
We have never been told the major specifics fo the situation!
So at this point via the present story,
bulls***!!!!!!!!!!!!!!!!!!!!!!!
