4WD System High Load is displayed
The indication is displayed under the following conditions. Park the vehicle in a safe place and check that the warning indication light turns off, and then drive the vehicle. Contact an Authorized Mazda Dealer if the indication is continuously displayed.
When the differential oil temperature is excessively high.
When there is a large difference between the front and rear wheel rotation, such as when trying to remove the vehicle from mud.
No s***, Mazda... Did you not notice that:
I thought this AWD system used all sensors to be smart.
Can it not say, "Awesome Donut!" or "Epic Drift!" instead?
Interestingly, it will still let you get squirrelly with the Traction Control ON. And Traction Control will kick in at high enough speeds even if you have the switch off.
The Traction Control switch is more like a 25% and 75% switch rather than full on and full off.
- It's below Freezing
- Traction Control is turned off
- Sport mode is on
- Throttle is to the floor
- Steering wheel is at full lock
