Thanks to all our supporters.
We have a following on the Focus (focaljet) forum, but the SCT tuner is big. Some have both. Besides the J&S Vampire, there is no easy way to add other piggybacks to the Ford ECU.
Competition (ECUTEK, UTEC, emanage) killed the Subie market for us, starting about '02, but these systems don't have individual cylinder control.
Igdrasil: Thanks for the link. You never know where stuff ends up.
Below are two screen shots, from two different engines. The first demonstrates the capability of the detector, the second shows the advantages of individual cylinder control.
Middle trace is the J&S retard signal, compared to AEM knock volts in the lower trace, on a 500hp Honda S2000:
Power curves from Ian Whiteside's NA F3 engine. The base curve (no J&S) provides a 2 safety margin from knock, as determined with knock sensing headphones. Remember, when tuning for "no knock", you are tuning for the cylinder that pings the easiest, robbing power from the others.
After installing the J&S and bumping the timing, the dyno operator could not detect any knock in his headphones.
