Evo Scooter
- 2003 Mitsubishi Evolution VIII & 2007 Mazdaspeed3
Very nice numbers!! So... Where do you get your tuning done? I have a MS3 I may need some work done on...
Evo Scooter said:Very nice numbers!! So... Where do you get your tuning done? I have a MS3 I may need some work done on...
JOMO said:www.billetdesign.com
Cwill works there. They can do wonders for your evo too. They specialize in them.
ok i'm gonna be running the mpi tuner, would i still need the j&s?TurfBurn said:Easiest way to sort out timing accurately and safely to the maximum is the J&S Safeguard. A lot of the bigger cars on here run them, and they are well worth the money!
Advance amount depends hugely on a lot of factors so it's not easy to just translate from one car to another, compression, turbo/intercooler efficiency, octane, spark plug type, etc all have an effect.
boostdprotegelx said:ok i'm gonna be running the mpi tuner, would i still need the j&s?
i'm saying...with my engine management/piggy back, will it work with, or can the MPI do this?Blackrose said:No one needs one per say. The J and S alows you to tune very agressively and if you made a mistake.... or there is an unwanted variable, the J and S will detect detonation and pull timing for you on the fly. It is a tool and also a safegaurd against potential motor damage. Its an awsome unit.
ok cool. i'm double checking w/ dana..since he'll be doing the install anyways.LinuxRacr said:MPI does not do knock detection. The J&S does work with the MPI. You have to hook up the J&S to the same fuel pump power wire if you do though I believe.
TurfBurn said:I don't think we know of a single protege motor that has popped when running a J&S.
Ddrop said:if you go megasquirt, you could prolly rig something up like the j&s safeguard...it would sure as hell cost alot less then a piggyback + j&s system
Ddrop said:pardon my lack of knowledge on the jgs system but...
Whats the difference between that and jgs knock sensor and a normal one? I thought a knock sensor was just that. How is the jgs able to detect real engine knock from engine noise? Isnt it just a normal knock sensor thats pre-set so it knows the difference between engine noise and knock?
Im aware of a few local megasquirters that are running 4 knock sensors with their megasquirt (1 er cylinder) . the software is totally programmible so that you can retard the timing as much as you want for whatever knock levels u get.
