sgryzko said:
Could be a dumb question but what do the three numbers mean??
First Number...
The Width of your tire.
Second Number...
The Profile (Height) of your tire as a % of the width.
Third Number...
The Rim Size the tire is made for.
Usually when you want to increase the size of the rim, the profile has to come down or you end up with a bigger tire and it will not fit.
EG.
205/50/16 is what the P5 came with...
215/35/18 is what I'm on now. Notice the last two numbers..
The rim size when up by two inches, but the height of the tire went down. The diameter of the tire remained mostly unchanged so the car still performs in acceleration and braking as it did, just because of the profile, there is less sidewall deformation around corners so more of the tire stays on the road...Better lateral traction (Cornering)
Also. The width gets bigger as the profile goes down. So finding a tire that fits is sometimes difficult to calculate. Your best way to shop is on the net with a site that has a tire calculator. They are everywhere..
Did you notice that the tires have a letter as well. Thats the speed rating. The closer the letter is to "Z", the faster the tire is rated for. Z is 245+ MPH. Really not required for a P5.
Z rated tires also wear out faster because they are made for grip and not long term durability.
Later...Brian
