.... The high Zinc and Phosphorus content help with metal to metal contact and the detergents in the oil helps keep oil cleaner" (resist contamination from the exhaust)...
Ummm... high phosphorus content in motor oil can also poison catalytic converters. Amsoil's content may be "high" but surely you're not saying it would be out of SAE and ACEA specifications. It would be noteable here that Amsoil historically has refused to submit for certification to any third party standards.
If you want truly HIGH ZDDP for wear protection there is a certain avid movement that advocate use of motor oil designed for diesel applications.
If you want truly HIGH ZDDP for wear protection there is a certain avid movement that advocate use of motor oil designed for diesel applications. Or used to be...I honestly don't know what the current trend is these days.
Depending on which Amsoil oil you use Z-rod or diesel or etc.. zDDP levels are around 900 to 1200 if I remember correctly .
I deleted the catalytic converter , EGR and Evap on my Evo. And vented to atmosphere on the pcv.
I had dual maps , E85 489 whp and 93 octane 421 whp. With this setup I ran Amsoil Diesel oil on my non diesel car for about 25k-30k miles . No adverse affects.
I needed higher Zddp to protect the HTA green turbos journal bearings. Mobile one changed their formula and those running hTA black , red , green or oem turbo with journal bearings needed the higher content to protect the bearings . Later they made dual ball bearing and that high if zddp content was not a must needed as much depending on setup .
Amsoil is not the only option though , there is Bred Penn , I think valvoline vr1 and many others as well .
Just something to add to this thread My vW GtI used castrol motor oil from factory . Oil change intervals recommended by vw was 10k miles or 1 year . But I don't know the zddp content of castrol brands of oil .
i take it you don't have emissions testing in your area.![]()
I take it you don't have emissions testing in your area.![]()
No, the system won't pick up your 3,600 miles of data and will start at 100% oil life when you set to flexible maintenance right now. But you can always set to flexible oil change interval any time you want for testing or fun. Just change your oil at 6 months period as you originally planned and reset it again for flexible OCI after you made your first oil change and you can go back to rely on flexible oil change indicator or change it once a year before the indicator is on.Has anyone changed their oil change frequency from fixed to flexible in the middle of a cycle? Meaning, when I purchased the car on 4/1 I had it set to fixed and planned on changing the oil every 6 months (won't be anywhere near the 7,500 mileage mark by 10/1), but now after reading more and thinking about it, I want to change to flexible. I am currently at 3,600 miles. Will the system pick up that data and incorporate it into the overall oil usage when I make the switch or will I have to wait until the next oil change to select flexible?
We have the same dilemma as our CX-5 has only 3,300 miles for 6+ months. I set to flexible OCI mainly for warranty purpose and I don't feel like changing oil at this time. I may change it before the weather is getting really cold during Thanksgiving Holiday where our CX-5 may have 4,500+ miles. I actually would like to do my first oil change at 5,000 miles but that would be in the middle of winter it's too cold for me. Since I used to do the first oil change early so changing it at 4,500+ miles is fine with me. After this I'd change oil yearly with about 6,000+ miles per year. I'd never let the OCI exceed 7,500 miles on our CX-5 with Mazda moly oil although the manual says it can be 10,000 miles for flexible maintenance. I have got oil change kit from Med Center with Mazda moly oil, OEM filter, and washer ready and I can change oil any day when I feel it's about time.Good to know, thank you. I guess I will just schedule my first 6 month free oil change on 10/1 and get it done. After that I'll set up as flexible.
I wonder if I should just wait to change at the 1 year mark rather than 6 months. There's no way I'll be at 10K miles before 12 months and I would still be within the warranty regulations. I don't see a real need to change at 6 months (10/1/15) when only at 3,600 currently.
make sure to ask your dealer to use Mazda moly oil for your free oil change!
I used to do my first oil change around 1,000 miles like you do for the new car. But I changed my habit after seeing many car manufactures suggesting not to do so. Honda even specifically says in the owner's manual that don't do the first oil change early as the engine has factory "break-in" oil and needs to stay in there for the first several thousand miles. I still attempt to do the first change earlier than maintenance schedule, hence before 5,000 miles on our new CX-5 no matter what the oil life says.I haven't read through the entire thread however I plan on doing the first oil change at 1,000 mile mark but not reset the flexible oil reminder. The next oil change should occur at 10,000 miles. I'll check the oil levels every few thousand miles. With a good synthetic oil it should last 10,000 miles with no problems.
