Installshield 2
Gothenburg Superiority
If you destroke the FS engine, you essentially make it the FP...which is the same for the most part, just less stroke and 1.8L...I am not positive on what happens to the rod ratio's on "destroking" an engine when you don't do anything to the crank...I haven't read up on that in a while, but to my understanding nothing would happen to the rod ratio's unless the crank geometry is altered as well...Some one clear that up though, that may not be right...iluvmacs said:Actually, no, but that's a great idea, although a bit tougher to do. However, when i optimized for hp, the volumetric efficiency got as high as 96%, which I thought was phenomenal. Torque peak was around 160 ft*lb with 150 at 1500 RPM lower and higher.
No, I don't. I probably should get it, although I'm really busy trying to close on a house, get married, and start my first job. I'll get around to it.
Is that flow based on the head, or bolt ons? I would understand if the head had better intake flow. There's a ratio that has to be optimized with that, but I forgot what it's called.
I understand about the rod ratio. It helps that most honda engines (minus the CR-V, some accords, etc with the 2.4) are relatively square. They also have a tall block. In a perfect world I'd get a miata crank and some longer rods to keep or increase the stock compression ratio. .2L of displacement doesn't seem like much when you consider the RPM benefits. Is the FS block any taller? I mean, after destroking, could the FS have a better rod ratio than the BP?
Most cars seem to run extremely rich, starting at the torque peak. That sucks because 70-75 mph is right in the torque peak and it sucks down gas on the highway at that speed. My other car, stock, runs 11:1 A/F past 3000 RPM. It's torque peak though is at 1800-3200 RPM.
Thanks for the replies. I know the FS isn't a great engine for modding, but if you consider that if you spent the same money on bolt-ons or top-end (valvetrain) parts as you did with a different engine, you'd get less output, but the car is already a blast to drive, and any improvement would just make it more fun. I'd be satisfied with 130 whp, knowing how many tickets I'm going to get when the car is stock....
Here's my plan for 130+ whp:
CAI (no hp increase, but sounds a shitload better, and cleans up the engine bay)
header
2.25" cat-back exhaust (custom, because chrome is for douches)
cams (lift has yet to be decided, based on vacuum and head flow)
intake (221 dur, -4BTDC, 45ABDC)
exhaust (236 dur, 50 BBDC, 6ATDC)
I don't like the overlap issue, but run that through DD and let me know if you can come up with something better.
Oh, and an ECU rePROM
But that engine makes about the same overall output in HP as the FS, less torque, and is much more willing to rev...it generally is said to be a slightly better starting point for NA...
