2003 Protege5 coolant temperature
I wish I was making the money I used to make, I've wanted to do that for a good while with the tablet.
You can get a used or older technology tablet for cheap.
It doesn't need to be cutting edge.
Our ECU'S run on Windows 95.
Lol
okay, the pitting was bad enough to let it leak past the seal, I seem to have found the housing and the cover since both are pitted. but at around 80 for both I might try something first... I also seem to have stumbled across a paper gasket that sits between the housing and neck to aid in the sealing for this exact problem. I am going to order that or just do what i've done before when I was missing a gasket for a stat housing, thin cardboard paper and some rtv very lightly coated on the paper. fingers crossed. it's only loosing a little coolant till it gets warmed up then it stops dripping.
Lol
yeah, but I like to do the whole thing when I do it, :ROFLMAO:, I want to re do the whole audio setup all the way down to deadner in the doors and roof. got a lot of other things that I need to clear off the "needs done" list before I can start doing the "I want this" list.
  • Like
Reactions: pcb
