1994 DOHC Manual transmission fluid change?
servfr
Hello,
Thank you for your help; I have a 1994 Protege DOHC with manual transmission, I want to check the manual transmission fluid and change it...dumb question, but how do I do that? Drain bolt is easy to view, but where is the filler and check holes?
Thank you!
Chris
There's no filler hole per se(sp?). You have to remove the speedometer drive from the back of the tranny and put the end of a long funnel in the hole, and fill up the tranny that way. Fill it till the oil reaches the driveshaft gear. Oh yeah, have fun- it's a pain without a looooong funnel.
Any advice on how to get speedo gear out?
I need to get this out to add fluid. I removed the bolt holding it down and there is no room to pry. Any ideas? Thanks
