194 LED bulbs
Dimitrios
Contributor
2012 CWP MS3
Anyone have good luck or can recommend a "hyperwhite" 194 LED bulb? I've used Eurolight "Xenon" bulbs in the past with good luck, but want something a bit more 'durable' - I figured LEDs would be the way to go.
Check out e-bay, I'm not sure of the quality of them, but it's worth a look. Also there is another size that is interchangable (can't remember which, do a search for my "Definitive Bulb Size" post to find out), you may want to look at that one too.
found it; apparently 912 and 921 is interchangable. I just blew out some new bulbs over the weekend and I'm thinking I put the wrong voltage in there - looking to replace the lisence plate bulbs...
18w vs. 5w?.....
194 should be interchangable with 168.
Are the lisence plat lights not 3652? I thought they were.
hmm..well, I went to www.xtremewhite.com and the 'search engine' there stated that the 912/921 sizes were for the lisence plate area - which I always thought the the wedge bulbs to be 194s.....
You are right with the 168 though...
