the other option is to go the other direction with the tire. I'm going for a 225/50/16 on a 16x8. almost exactly matches the OEM diameter, and fills out the tire well nicely on a light drop.
my point was both wider and taller, as opposed to shorter and skinnier, but thanks, the smartass remarks are great value added. LOLwell uhh yea, a bigger tire would be the only other option than a getting a smaller one.
Yeah justin I Love your car man looks great!
And are the sportlines going to prove to be a better drop than the s-techs? Any opinions?
Btw justin how low is your drop?
Alright well if I can find a set of White Gram Lights 57Maximum's for a bit cheaper I'm probably going to grab a set of those. Im not too sure on the 16 vs 17, I only plan on buying a set of lowering springs not full coilovers so would the drop from springs be sufficient enough for 16s?
I just installed Eibach Sportline's on my MSP today, I'm running 16x7 +35 wheel's that came with 205/40/16 tire's when I bought them. I will take a pic and show you how the drop look's with spring's in a few day's when they settle...
The drop is "ok" not slammed like coilover's but, good enough for me! I do plan on getting a wider/taller tire 215/45's sometime when money allow's. that should help lower the amount of wheel gap some.
