104 MPH @ 13.16 seconds
you guys are in oakville? I am in Oakville too! I cant upload the vid cause I am at work, but my friend was at the track a few days ago and said he saw a speed running those times that had a westtown mazdasticker on it? not sure if it was you, but he was running 13.1s too. (on an unrelated topic, I was at westowne mazda the other day having some work done and I saw a orange speed having a clutch and fidanza flywheel put in. I went into the service area and took a look at the car. It seems identical to the mods you described but it had hardpipes, was that your car? BTW-it looked pretty neat to see 2 spicy oranges on the lifts beside each other lol )
that is an awesome time...and i just realized something(please no flame wars here).
Stock SRT-4 psi is 15lbs, right? and they run low 14s-high 13s stock.
So with your boost still lower than a stock SRT, plus the intake, exhaust, and FMIC you managed a full second faster...I must say that IS quite impressive.
wow sweet times....def encouragement to get mine to to the track....yea im also curious about how much of a different the rim size made. I know my buddies 240 gained .5 when goign from a showy 18 to lightweight 15s with drags...
have to remeebr the thicker rubber may still keep the radius near identical to the stock 17" with 45 profile.......but a small radius normally drops top speed in favor of faster 60ft /acceration since ur basically dropin the gear ratio
225/50/15s have a .7" smaller radious than stock MSP tires, so although its minimal, it may have cut down the trap speed a tiny bit, but improved the et :D
Wiggles422 said:
The only # that counts to me is the ET.
i used to think like that too, but its hard when ya got FWDs running fast as s***(high trap speeds) but they cant hook up(lower ETs), RWDs running pretty even ET versus trap, and AWDs that run ridiculous ETs that trap the same as a FWD running a half second slower ET...
ya gotta lookat the big picture for an overall car, unless its competition then nothing matters but the ET :D
I believe Xsivspd is in Oakville...I remember seeing his plate.....I have seen at least one other besides xsivspd in town...
Phil that is sweet man, hmm I wonder what you would run with a piggy back and some higher octance fuel :)
