1.8t
Yeah the VW and Audi 1.8T's have horse power ranging from 150-180 and there is quite a difference between the high and low.....my buddy has a 2000 Passat with the 150HP 1.8T and it is slower than my g/f's 180HP 1.8T Jatta.
Believe the VW Bug had the 150HP version when it came out?
KySpeed said:
what was done to the tiburon to make 240hp
More than likely a Supercharger. That seems to be the route to go if you want alot of power with those cars. I know of a few guys/girls with some pretty powerful Tiburons. (Including a 311whp one) My Friends with I/E/P ran consecutive 14.6s (but only puit down 165 whp (dunno) )
never raced or driven a tiburon they came into my mind for a split second when considering a new car then i remembered they are still hyundais lol
1.8T's are a beast for a stock motor. Ive raced stock MSP's and stock 1.8T Jettas, I get ***** so had by the 1.8T, the MSP wasn't much quicker than my P5...
The 1.8T's are some decent cars. We have 3 in our crew ( GTI, Wolfsburg Jetta, and an 04 GLI). The GLI is the only one that's not chipped, the other two are both chipped and running turboback exhaust... The other two are a handfull, either off the line or from a roll. Be cafeful, if you get caught slipping, they will hand you your arse...
I love my g/f's stock Jetta 1.8T we got a couple months ago. I thought they were pretty close to the MSP if raced stock. I have not been in a MSP driven hard and I take the jetta out once in a while. I took Astral for a ride last night after we installed his optima before we went to the bar......he was impressed with it. The Mazda's do handle a lot better then the stock Jetta GLS. Not sure about the GLI.......
It was this kids Wide Body Tiburon V6 with:
Dual Exhaust
Intake
Headers
FlyWheel/Crank Pulley
Clutch
not sure what else was does thats all I remember...
Hmm... my 337 is pushing 2900lbs. The weight varries a lot more than you would think on the Mk4 platform. The new GLi's are 3200, I think the normal GTi's are around 3000, with the 337 is in the mid 2800s and the 20th Anniversary GTi is in the upper 2800s. I would say drivers race, but I think a moded 1.8t would indeed gun down the MSP for sure. Also the GLi, 337, and 20th AE all use the same six speed tranny so they require an extra shift in the 1/4 mile. I dont understand why the GLi weighs so damn much...
my friend has a AWE chipped 20th anni GTI. i raced him w/ just a mbc set to 9 spikin to like 11. we went from a roll, not much skills needed, we were pretty even 2nd -> 4th w/ him pullin maybe a fender if that.
What excatly is lighter on a 337 or 20th AE? It has heavier wheels than a normal GTI 1.8t, different seats, some interior trim, different seats and, lowered suspension with some different tuning- what else?
I really couldnt tell you why the 337 and 20th are lighter. The 18in BBS RCs on the 337 only weigh 19lbs each, the Aristos on the 20th are 20 something... The 337 lacks a sunroof which is why it is lighter than the 20th, and the rims are lighter. Unless the 6speed on the 20th and 337 is lighter than the 5speed I couldnt tell you.
20th AE info:
A base GTI GLS 180hp 1.8T is the starting point to which the following significant changes are added:
- all-new 6-speed MQ350/O2M350 transmission
Gear Ratios
1st: 3.42
2nd: 2.11
3rd: 1.48
4th: 1.15
5th: 1.17
6th: 0.97
Reverse: 2.50
- Same upgraded brakes as the 337 (12.3 inch front rotors, 10 inch rear vented rotors, better pads, red powder-coated calipers)
- Same suspension as the 337 (uprated springs and shocks, increased sway bar diameters, and revised bushings in the rear)
Eibach springs that are 20% stiffer than stock (same as DriverGear), 23mm RSB, 21 FSB (sways same as regular gti), gas charged Monroe shocks, metal/rubber rear bushings (instead of hydro)*, 30mm drop
- 18" R32 Wheels with ultra high-performance rubber
- Same body kit as the GTI 337
- Same Recaro seats as the 337 but interior theme will be silver/grey and black instead of the red/black in the 337
- Blacked out headlamp interior surrounds similar to the German market 25th AE GTI
- New instrument cluster with aluminum trim bezels from the German market 25th AE GTI
- Black headliner
A pillar left: 1J0-867-351-B-54A
right: 1J0-867-352-B-54A
B pillar left: 1J0-868-417-J-54A
right: 1J0-868-418-J-54A
C pillar left: 1J3-867-241-B-54A
right: 1J3-867-242-B-54A
Headliner with sunroof: 1J3-867-501-AP-54A
- A few additional aluminum trim pieces (around HVAC controls)
- 4,000 units total in the U.S. and 200 units total in Canada
- Cars will be numbered via a dash plaque
- Retro rabbit badge along with red "retro" GTI logos front and rear
- Sunroof will be standard
Paint codes.
Jazz Blue = LW5Z
Imola Yellow = LY1C
Black Magic Pearl =LC9Z
Weight - 2916lbs.
Wheel weight - 48lbs each with tire.
'05 GTI 1.8t from Edmunds.com=
<TABLE cellSpacing=0 cellPadding=2 width="100%" border=0><TBODY><TR class=table-sub><TD width="50%">Length: 164.9 in. </TD><TD width="50%">Width: 68.3 in. </TD></TR><TR><TD class=stripe-five width="50%">Height: 56.7 in. </TD><TD class=stripe-five width="50%">Wheel Base: 98.9 in. </TD></TR><TR class=table-sub><TD width="50%">Ground Clearance: 5.1 in. </TD><TD width="50%">Curb Weight: 2934 lbs.
</TD></TR></TBODY></TABLE>
So there's about 20 pounds difference between the two.
my buddy chipped his 1.8t and stomped my ass.....prior to the chippin it was a dead even race....
BlkZoomZoom said:
until you don't do oil changes on time.
have you owned a VW brian? you seem to have a huge hate for them.....you must be looking forward to the weather warming up again so you can ge to the track again?
-R
I work on VW's. I have a hatred as only a tech. can.
It's gonna be intresting to see how I do this year, it's gonna act like a whole new animal.... no more 13's for me.
