Parts sold list:
Side markers, shift knob, washer kit, lower grill, door sills, headlight supports, ecu cover, DF inner wheel plastic cover, egr tube, cup holder(shifter bezel), inside DR door handle, shift boot, Ebrake boot, TURBO KIT(rad+intercooler, rad brackets, turbo, wga, oil+coolent lines+ oil cooler, exhaust mani+shield, S+J pipe, hot+cold pipes, air box, MAF, BPV+hose, MSP ecu, ac condensor), PR door complete, rear strut hats, front A pillars, Engine, headlights, RB springs, climate controls, insturment cluster, wheel center caps, coolant reservior, engine harness, glove box cover, fog deletes, msp engine cover, R skirt, hood latch, msp pedals, dual cat, both O2 sensors, dash bezel, rear cross member, bumper cover, pass axle assm, bump stops, spare tire and cover, dipstick, DS jam sill, coilpacks+plug wires, DS rear caliper, DS front caliper, TRANNY, DS door, DS fender, 03.5 LIP, PS rear view mirror, radio bezel, grill, pr seat belt assm, horn, sub brackets, Pass ABS sensor, Driver's side hub and axle, pass window switch bezel, brake booster line, sub encloser kit, fuel pump, fuel pump assembly, dimmer switch, seat covers set, radio pocket, ac compressor, rear MM, shifter, shifter plate, shifter link arms, master cylinder, clutch master cylinder, slave cylinder, clutch line, throttle cable, gas-brake-clutch pedals, pressure plate-clutch disc, flywheel, starter, 03.5 spoiler, gas door, trunk mat, front RB sway bar & bracket/ bushings
