03.5 Blazin yellow MSP partout
Status
Not open for further replies.
interested in the banjo fitting that connects the coolant feed on the back of the block. pm me if that is something you can do?
any parts left for the rear driver's side hand brake? I basically am looking for everything except the caliper and cable. (Spring, mount, etc) lmk
Interested in PS fender
Sold
sold
yes I can help you out there. I'll pm you
Got the drivers side a pillar cover?
you talking about the A pillar that a gauge pod would mount to? If so it's sold
You meen the quarter Panels? I believe the rear pass quarter panel was damaged from the wreck. Have to double check
A/C bracket between the compressor and the block?
As well as all bolts that go into the block and the compressor?
Thanks
abs sensor
Hello am lookin for the abs sensor the left rear one if u have it please let me know thank u.
Still have the spare and trunk liner? You should have sold the entire thing to me a year ago and saved yourself all the trouble of constantly checking this thread :)
Thanks
Might have it. Need a pic though to make sure
u.
all sold
Spare and liner are sold. Should've, could've, would've! Still can sell you whats left.... But yeah I'm over it
Updated list of parts that have been SOLD:
Side markers, shift knob, washer kit, lower grill, door sills, headlight supports, ecu cover, DF inner wheel plastic cover, egr tube, cup holder(shifter bezel), inside DR door handle, shift boot, Ebrake boot, TURBO KIT(rad+intercooler, rad brackets, turbo, wga, oil+coolent lines+ oil cooler, exhaust mani+shield, S+J pipe, hot+cold pipes, air box, MAF, BPV+hose, MSP ecu, ac condensor), PR door complete, rear strut hats, front A pillars, Engine, headlights, RB springs, climate controls, insturment cluster, wheel center caps, coolant reservior, engine harness, glove box cover, fog deletes, msp engine cover, R skirt, hood latch, msp pedals, dual cat, both O2 sensors, dash bezel, rear cross member, bumper cover, pass axle assm, bump stops, spare tire and cover, dipstick, DS jam sill, coilpacks+plug wires, DS rear caliper, DS front caliper, TRANNY, DS door, DS fender, 03.5 LIP, PS rear view mirror, radio bezel, grill, pr seat belt assm, horn, sub brackets, Pass ABS sensor, Driver's side hub and axle, pass window switch bezel, brake booster line, sub encloser kit, fuel pump, fuel pump assembly, dimmer switch, seat covers set, radio pocket, ac compressor, rear MM, shifter, shifter plate, shifter link arms, master cylinder, clutch master cylinder, slave cylinder, clutch line, throttle cable, gas-brake-clutch pedals, pressure plate-clutch disc, flywheel, starter, 03.5 spoiler, gas door, trunk mat, front RB sway bar & bracket/ bushings
Status
