The two wires previously described. The orange wire going to the alarm control module (there is a good pic of the module about two or three threads back). That wire gives 12V when the ignition is in the ON position, 0V if not in the ON position. If you cut it then the alarm will always think the car is off (but it doesn't affect the alarm operation otherwise). The alarm is not armed by itself, it is alarmed by the remote door locking system. That sensor is located behind the back seats right about in the center underneath the plastic that is below the back winshield. It is very close to the seats so all you have to to is put down the seats, take out the little plastic pieces that hold the plastic cover and just fold it up a bit. Cut and properly insulate the engine side of the blue/white wire. All that wire does is provide the 12V when your ignition is in the ON position, and 0V when not. So by cutting both your remote door lock and your alarm will never know if the engine is running and you can activate them anytime (including when the car is running down using the turbo timer). If your alarm goes off, usually after you shut it down the light behind your steering wheel will flash really fast. This is just to tell you that your alarm went off. Now that you have cut the orange wire when you start your car that light will not stop flashing. Not a really big deal. If it is annoying you just arm your alarm using the lock button remote lock control and it will stop. Otherwise your alarm funtions normally and still even disables the starter when it is set off. I am not trying to convice anyone what to do, but as a journeyman electrician and currently an electrical engineering student I stand by my last post. I assume most of you doing this have very little electrical experience, and instead of tapping into the ignition wire just cut the wires and insulate the ignition side of them. This will work, and it is very easy and safe for you to do.
