How is your ride quality with 20" wheels?
2023 CX-5 Premium; 2018 Mazda 3 GT hatch
I've read quite a few comments in the automotive press about the poor ride quality of the CX-50 with 20" rims. Unfortunately, that would be the only wheel associated with the trim levels I would consider. So I'm wondering how folks who have that setup feel about the comfort level of the car?
The ride quality on the CX-5 sig. loaner i drove (19's) was awful. slow to respond, cumbersome, heavy, so much unsprung mass, took otherwise good crossover suspension tuning and made it feel virtually useless.
My wife has a '23 CX-5 with 19s and we've recently had occasion to rent the same car with 17s and there is a noticeable difference in ride quality. That's why I'm wondering if the same is true with the 20" CX-50 or if Mazda has tuned the suspension any better with the newer design. Also, my 2018 Mazda 3 has 18s and the ride can be a little rough, but you expect that on a smaller car with shorter wheelbase and besides, it handles a whole lot better that its SUV counterpart!
Massive, heavy OEM wheels and giant tires can't exactly be tuned for. That unsprung weight will constantly be working against the suspension. Even the 18's on your 3 are going to be heavy.
The 17's on my 6 with the same aspect ratio as a cx5 sig (55) felt much better.
I'm changing to some flow formed wheels in spring that are 10lb lighter per wheel than stock.. that will make a huge difference.
If you're serious about the cx-50, I would put lighter downsized aftermarket wheels on it.
Having driven a CX-50 with the 20's and another with the 17's, and CX-5's of both generations and with the 19's and 17's, AND having swapped my 2nd Gen CX-5 19's for 20's with a completely different (and better) tire, I can tell you with 100% certainty that what you are describing is the fault of the 225/55/19 Toyo A36.
I wasn't happy with the feeling that the rear of the car and the front seemed to respond at different rates, with the back lagging behind the front, when shifting direction at highway speeds. The main problem is that it's not a sporty tire and responds slowly.
My lowering springs with higher rates probably helped with this as well, so consider that into the equation.
