2016 Mazda CX-5 Touring Halogen to LED
Hey, everyone! I'm new here. I have a 2016 Mazda CX-5 Touring, which I believe has halogen headlights (they are dim and provide poor visibility during night driving). I'm interested in switching to LED.
I have two options I'm considering:
Option 1: Replace the current halogen bulb with an LED bulb. Would there be any issues with this approach?
Option 2 (Preferred): Replacing the headlight assembly with an LED option that has the halo design. I've linked what I'm looking at on eBay below. Would this aftermarket option be compatible with my model and reliable? Or should I stick with OEM?
I appreciate your advice!
Idunno about the replacing the entire headlamp assemblies but I did replace the halogen low beam bulbs on our 2016.5 touring with LED's. Inexpensive and great results with no issues. Plug-n-play. Much better illumination without being annoying to other drivers.
Thank you! That's very helpful. Would you be able to share the model of LED low beam bulbs that you used? My biggest concern is blinding other drivers with a glare since I'm guessing my assembly is built for halogen, but if you haven't had issues then I'm interested.
Sure ...
AUXITO-H11-Headlight-Bulb H11-LED
I too despise the roadway epidemic of blinding LED lamps installed in fixtures not designed for them! When I installed these, I had Mrs. Hyflyer drive behind me and oncoming on a dark two lane road to make sure our vehicle is not going to be like that. I think it's because of the projector design of the housing.
Diode Dynamics makes excellent products with a lifetime warranty as well. More premium priced.
