Mazda5 sound deadening complete
Sorry, can't remember. Probably 1 pound though, because I was able to get it behind the door cards pretty easily.
Thanks! I was figuring/hoping just 1 lb should be effective after deadening and closed cell foam on the floors. Wheel arches next!
Can you share a link to the product? I'm only coming up with Butyl mat type solutions from Noico.
On a related note I scored a shitload of Thinsulate off FB Marketplace yesterday for $cheap. Is that suitable for under-carpet usage, or is that a moisture trapping concern?
You all have never driven Jeep products. Our new to us 5 is down right silent compared to our Jeep Patriot and Wrangler unlimited. I won't be messing with this for the 5, but I was thinking about it with the patriot. That thing was L O U D.
Home depot and Lowes sell window flashing rolls of "dynomat", only generic.
I usually paint everything with a gallon jug of bedliner and a brush. It sound deadens and keeps rust away when your rugs get wet. It is also a good time to put it in the inner fender steel parts.
If you put bedliner in the doors, put straws coated with wax in the drain holes at the bottom. Having a door bottom full of water sloshing around and soaking your feet kind ruins a day.
Oh good LORD no! Don't use that stuff, it STINKS. Like, really, really STINKS. It's made for outdoors, not indoors, and especially not inside of a closed space like a car!
Agreed, just like don't use pressure treated wood on projects indoors, or any project you want to eat on like a picnic table etc.
They are several different brands of that kind of stuff, some with quite a bit of asphalt, others just rubber-type (and additives). They have Gorrilla brand, FLEX-SEAL, a brand for RVs, etc.
Amazon has a bunch of that stuff, too.
FWIW, I'm waist deep in this same project right now. I think the original post is a little alarmist. There is not zero sound deadening. There are anti-vibration patches all over the place, several large styrofoam pieces, several large sound deadeners that look like carpet underlayment, and also the back of every large interior panel has sound damping material on it.
Still, its a noisy car, and I hope all this helps.
Inside of rear panel for example:
Carpet upside down. Its a multi-layer stackup that makes an attempt to deaden sound.
I have used it many times. I never noticed a smell. I buy the aluminum faced, window flashing. I've done at least a half dozen vehicles over the years. The brush on bedliner does smell for awhile.
Butyl doesn't smell, whereas bedliner, bitumen and asphalt based products aren't for confined spaces because of stinky carcinogens.
