2025 CX-5 Lowering Springs
Hello All,
I'm new here and am trying to find out if anyone has lowered a 2025 CX-5. I am wanting to lower a base model 2025 2.5L.
Corksport says their springs are compatible with the 2025. H&R says their springs have only been tested as far as the 2023 model. I am awaiting a response from Eibach.
Does anyone know if there are significant changes in suspension across the 2017+ CX-5s that would cause incompatibility with respect to lowering springs?
Thanks,
Todd Brasher
The CS springs were designed for the AWD Turbo, so the ride height will be slightly higher in the front with the lighter NA car. Probably not a big deal. But as long as you are AWD they will work.
I wouldn't suggest using lowering springs for the turbo version, on the NA car. There is a weight difference.
I really want to go with the Eibach set. I think the only way to get them is from Europe, unless someone here may know of a USA source.
The original struts on your car are long lasting. I'm well over 300k km on my original struts, and they are still firm. Lowering springs will greatly reduce their longevity. Consider coil overs.
2022 Signature Turbo with Corksport lowering springs. Rides and handles better than stock.
What is the life expectancy of a set of coilovers vs the stock struts/springs?
I would definitely expect OEM to last longer. But there are simply too many variables to give a definitive answer on how long when compared to each other.
Absolute truth coil overs will perform better!👍 Just making a daily driver with the CX-5. My other car is for spirited driving.😁
The shape of that Jag is bebeautiful
Thanks! Original plan was to sell it, as it's very difficult for me to get out of these days. But, every time I take it out of the garage to clean it up to sell, I take a drive thru a local canyon, and it goes right back in the garage. Then I have a hard time wiping the smile off my face for a few days. Lol
Looks really good, don't agree with the better ride but I do agree with the better handling (y)
Probably right. My other car has kinda that sports car feel, and I've gotten use to that. The 5 felt top heavy stock. Mine will likely never see more than a dusty paved road. Lol
