New Transmission Costs
2018 Mazda CX-5 GT
Hello,
I have a 2018 CX-5 Grand Touring Edition - 95,000 miles. Every time the car shifts out of gear it "jerks", mechanic said I need transmission. I am not savvy enough to know if he is right or wrong but he is trusted. How much should I expect to pay for a new and/or reconditioned one? I am in PGH, PA FWIW.
Thank you,
Glenn
Hello,
Thank you,
Glenn
Have you tried resetting the transmission into learning mode? It can work well to clean up undesired behavior and is used as a diagnostic step often. If the behavior cleans up and stays away you don't have a mechanical issue, if the behavior comes back then you may have something starting.
X2 change the fluid and trans filter. While the pan is off, look for any metal in the bottom of the pan.
Have you pulled the trans level stick and looked at the ATF? Does it smell burnt? Is it red, dark red or brown? Red is new. While you into it, confirm the ATF level is correct...
Hello,
He is wrong.
but he is trusted.
No, he is not. I would stay away from this mechanic.
You should not expect to pay for a new transmission period.
@sinistriel@
please input here - my understanding with the jerk into drive, is that, assuming fluid level OK, that there is wear in the valve body. The transmission would need to be dropped and inspected inside, cleaned, new fluid added, and if that doesn't resolve it, then valve body rebuild would be needed?
if the pan is taken off, the bolts must be replaced... mazda says so
Most likely I'd reuse the bolts unless the threads are full of rtv.
I might order bolts from McMaster-Carr. There is nothing magical about trans pan bolts.
Honestly, Mazda over engineers many items on this car, then puts rtv on the trans pan....
Like they really expect folks never to service it!! 🙄
He is wrong.
@sinistriel@
There is really not enough info of the concern to give any sort of accurate diagnosis. I'd need to experience it to see. If they have CD and its on every shift besides engagement it could be a failing torque converter, it could be failing/failed motor mounts, etc.
they don't expect people to service it, that's why there's no transmission service interval in the manuals
and a well maintained transmission doesn't really need the pan dropped... there's plenty of evidence out there that the magnet in a 30k mile interval pan drop is pretty clean... with that in mind, your choice to drop the pan and clean it up, but it's not necessary and it's purely an OCD thing
RTV is more reliable than gaskets anyway... everyone practically switched to RTV for engine oil pans decades ago and it's been fine... they do a better form fitting seal than a gasket... plus gaskets can swell and shrink, whereas RTV Doesn't
The op thinks he has a trans issue. Dropping the pan will allow for inspection for metal and change the solenoids and or valve body.
While it's open, now is the time to change the trans filter. As the filter captures clutch material it has higher and higher pressure drop until it starves the trans for fluid and or comes apart. 100k mi on a trans filter is a lot. It's past time to change it.
Properly designed gaskets are equal and better than rtv. Mazda cheaped out in this area. Today's gaskets seal extremely well and can be reused.
Mazda is trying to kill this trans after X miles to get the owner into a new car by not recommending changing the atf and filter. We can correctly assume Mazda knows how long that trans will last without service.
In the HD pickup world a properly maintained trans will go well past 250k mi. Atf and filter is changed ever 30k mi. I know of one that has over 430k on the original trans. He services the trans every 30k mi.
I said "a well maintained transmission"... you missed that part didn't you? I wasn't disputing the fact that the OP should get the pan dropped for cleaning/inspection because its condition/maintenance history is unknown... but my point still stands that on any well maintained one, it's pretty unnecessary unless you're OCD
there's plenty of Japanese (especially toyota) transmissions out there that just had 30k drain and fills all of their lives and last well past 250k until the car either wrecks out or rusts out or the owner gets tired of it and moves on
there's also evidence out there that some skyactiv mazda owners never touched their transmission at all, and it lasted well past 200k miles and much more beyond.. exceptional? maybe, but it wasn't just 1 person but a handful... will I put my faith in the "sealed for life" nonsense? no, I'll still regularly change the fluid, but I have faith it'll be fine with just timely drain and fills without needing to spend more time with a pan drop and filter change... you can leave that for domestics (almost all of which have no drain plugs) and their crappy transmissions
and all gaskets are designed for one time use... if you think/want to risk reusing a gasket, go ahead.. I wouldn't do it at all, let alone non-critical parts... it's not worth my time having to redo something just to save $20 on a gasket plus money spent on new fluids on a redo... you can argue that mazda "cheaped out" using RTV, but like I already said, it's been proven better and more reliable for decades with sealing pans, blocks, and cases with many manufacturers, even toyota back in the 90s where they weren't known for nickel and diming on engineering/production expenses... you might think RTV is cheap because you might be used to buying the crappy $10 consumer grade tubes at the parts stores, but what the factory uses and what you can buy from the dealer are leaps and bounds better... might look the same, but not the same in chemical composition, pressure tolerances, heat tolerances, chemical tolerances, and durability/reliability
No matter how condescending you continue to reply we will continue to disagree.
Gaskets have come along way. On my German Nag1 the gasket is aluminum with flex material on both sides. Same thing on my Domestic Dodge, 48re.
Fwiw, I took out my Domestic 48re when changing out a band incorrectly. It had 250k mi and was going strong. My buddies 48re has 430k mi on it behind a Cummins and he tows a 5th wheel trailer.
Blanket, all inclusive, statements usually are not true.
The point, metal gaskets are reusable, I NEVER had to go back and replace because they leaked. These are light years better than the best rtv.
Time will tell if not changing your transmission filter is okay or not.
For me, the extra time to drop the pan, scrap off the rtv while berating Mazda, so I can change the filter is worth it.
Changing engine oil and transmission atf, includes changing the filters.
Enjoy 😉
Its obvious that Mazda amongst other manufacturers don't want their transmissions to be serviced properly for a corrupt method of profit.
@AL Cx5 These transmissions have a strainer, not a filter.
Based on what the bottom of my pan has looked like over the years with each service, I'm in the camp of: Drain and fills are fine until a certain mileage, but still consider having the pan dropped sometime after 100,000km.
@TheMAN feel free to disagree, but please try to keep it friendly and respectful. Both of you are solid contributors to this forum; let's keep it amicable and productive.
I'm due another drain and fill at 150k miles (30k since my last one done at 120k). I have never dropped the pan, but I think I want to just because of where the mileage is now. I also am interested in replacing the strainer. But would also like the see how the bottom of the pan is looking.
Still deciding if I want to do this work myself (never dropped a pan before), or pay someone to do it.
Enjoy 😉
Did you use a filter that came with a gasket? If so which one did you use? Or did you buy the gasket separately?
I'll buy a filter/strainer with gasket when I drop the pan.
Here is a link where the guy cut the filter/strainer on his Mazda. Gee it sure LOOKS like a filter media to me. I haven't found a micron rating for this item. I'm NOT impressed with this filter/strainer. My Domestic and German transmissions have real filters. Maybe an aftermarket filter with some real media in it will surface.
https://bobistheoilguy.com/forums/threads/2018-mazda-3-trans-service.396831/#post-7281514
Or add a remote trans filter. I had left over parts for a remote spin on fuel filter on my race car that I used on my Domestic rides transmission with 280K on the original engine. As mentioned, I killed the trans at 250k with a bone headed mistake. It would be way cool to have a spin on remote trans filter on the Cx5.
In the link, the bottom of the pan has a good bit of clutch material around the magnet. Fresh ATF every 30k is still on my list. I'll drop the pan at 90K and change out the FILTER/strainer. I don't want to circulate contaminated ATF through the bearings, gears and valve body.
I'd like to hear from folks if they notice a difference in how their trans shifts after changing the ATF. On my other rides there is a noticable difference after changing fluid.
I was thinking of installing a magnefine filter on the line between the trans and the cooler
I had a magnefine inline filter on my Domestic ride. It worked just fine. It would still be there but I wanted to repurpose the remote filter housing. It's very important to remember to change it...
