Sure, full body PPF + piano Black inside + hydrophobic coating on all windows was around 4300 USD acording to current conversion.
This weekend I've done about 400km traveling in rain and bad weather and can say it was worth it :)
But this is my subjective opinion. I like to have a car that should last a long time :)
I was planning on doing the front bumper and hood. I was quoted at $2500. You got a better deal.
Sorry I can't upload better resolution, guys, we're stuck at 1280x720 like it's 2005!!!
You can host your images elsewhere if resolution is an issue for you. imgur.com is free to use, for example.
Thnx for this info. Had no idea they made bumper plugs. Unfortunately, the state I leave in, front plates are required. For this pic only, I removed them.
So does California and I haven’t installed one on any car I’ve owned in over 50 years!
I warned my son to put a front plate on his Mercedes. In less than a month, he got pulled over for no plates. Local cops in my area don't bother us for plates, only state troopers will. CT troopers are anal about everything.
I added a grill mesh insert to the front of the car.
Me too:
I, for one, like the exposed intercooler over the two matching sections. Something about them being disconnected and different shapes, compared to the tuner vibe and keeping just the main grille looking like a grille.
It is an exact copy of the grill, both in terms of shape and texture.
For convenience when applying, I temporarily dismantled the number plate, nothing else. It is attached with double-adhesive tape. Just to be sure, I have fixed it behind the number plate with black tie wraps. There is no need for drilling or screwing.
Because my license plate is quite wide, I had to cut a small corner out of the left and right part of the new grill.
That is correct. I was able to fit this grill with the front plates on. My plates are standard size, so I had no issues cutting. It has 3M tape on it. It fits snug. It will not fall out. If you plan on buying this, get it from Amazon. Ebay is currently selling the same grill for $89.99. I just checked Amazon, it is selling for $26.14 with a 10% off. That's a good deal.
So it looks like you pretty much have to use the front plate in order to hide the vertical seam between the two pieces?
It is a two-piece grill (left and right) with a hole in the middle for the license plate.
The website states: "The grill fits perfectly for a 2022 2023 2024 CX-5 (with FRONT LICENSE PLATES) front bottom grill slot".
In the reviews I read a solution (including some small pictures of the front of a CX-5 without a license plate) with two sets:
"4.0 out of 5 stars Great, but doesn't cover the front license plate.
Reviewed in the United States on November 9, 2023
Color: 2022-2024 CX5 Front Grills, Verified Purchase
Before my review misleads anyone, I purchased a total of four pieces and cut two of them off to cover the front license plate area.
That's a great idea. I might just do that.
Really fun day, 2018 with 117k kilometers in my driveway Inspected Front Brakes,
Suspension and Steering then replaced Left Rear Wheel Bearing, Rear Pads and Rotors.
What was the symptom of your LR wheel bearing, or how did you figure out that it was your LR wheel bearing failing?
Rumble or roaring sound increased with speed. Originally considered it was on the right side since the sound would change with a left turn. When I checked it on jack stands I found the sound was actually on the left rear. It's a DIY but access to the four bolts is difficult and required heat and penetrating oil.
