Okay so aprox. 1 year ago I brought my 2.5l Mazda6 in to have my tensioner replaced (did not have right tools nor knowledge on how to replace it myself at the time). During that inspection the dealership noticed the water pump was leaking and even showed me noticeable dried green leaks. Got everything even tensioner replaced under warranty for free.
Fast forward one year and periodic (every oil change) inspection by myself on the tensioner for the CX-5 and Mazda6 all has been good. I have been doing all my maintenance after both cars' warranties expired.
So what do I see today on the Mazda6's tensioner...no not leakage hooray...wait what that tiny bit of green stuff? Further inspection towards the areas surrounding the water pump had small amounts of green stuff seemingly sprayed vs dripped. Small amounts but my watchful eyes caught them. I used my wife's mascra mirror
Dammit!!! It was not there before.
So I research and what do you know I found this: https://static.nhtsa.gov/odi/tsbs/2016/SB-10092584-6903.pdf
Apparently the skyactiv engine's water pump has a weep hole. Trace amounts of green coolant like mine if actually normal. The bulletin provides some sample good vs bad water pumps (although samples are not our water pump). Bottom of Page 2 of 4 shows a sample of the weep hole of what I first thought was true skyactiv water pump.
If easy to wipe off = Normal.
If crusted = replace water pump.
Got it.
Indeed the blow off of the coolant was easy to wipe away. However I could not locate that elusive weep hole. I tried using my hand to feel around where I could not see. All I could feel is smooth metal and no crusted spots. My idea is to head over to a dealership or car parts shop to look at a new water pump in my hands.
In hindsight I think the dealership prematurely replaced my water pump last year. (dunno). The service bulletin indicates: "There is a concern that some water pumps are being replaced that are not faulty, due to signs of a very small
coolant leak from the bleed hole. This Service Bulletin is to inform you about the water pump sealing mechanism and the criteria if replacement is necessary or not."
Got it.
