 - Central Virginia
 - 2019 CX-5 Reserve
This is from the 2019 manual (Pg 4-65):
Active Adaptive Shift (AAS) automatically controls the transaxle shift points to best suit the road conditions and driver input. This improves driving feel. The transaxle may switch to AAS mode when driving up and down slopes, cornering, driving at high elevations, or depressing the accelerator pedal quickly while the selector lever is in the D position. Depending on the road and driving conditions/vehicle operations, gear shifting could be delayed or not occur, however, this does not indicate a problem because the AAS mode will maintain the optimum gear position.
It sounds like the shift points constantly change.
The only discussion in the 2019 manual regarding specific speeds in specific gears is the discussion on when to up-shift when in Manual Mode. (Pg 4-69)
