Mazda CX-5 Tire pressure monitoring
What are the PID numbers?
In FORScan
Here's what I use for Torque Android app.
It has an auto sleep feature and worked fine with my previous car with no battery drain. I think it wakes up Bluetooth when it sees ignition on the obd2 bus.
In torque settings you can import the pids.
I added HP which calculates HP from the actual torque value and RPM.
I also checked which tire is which.
I'm in the US, left hand drive.
1 - driver front (left front)
2 - pass front (right front)
3 - driver rear (left rear)
4- pass rear (right rear)
I got this one. The sensors a about the diameter of a dime. Seems to be very accurate with no air loss over the last month. If you need your outlet you can always get 2-into-1 adapter. BUt this looks pretty darn clean, IMO
View attachment 310105View attachment 310106
After discovering this little tool, I have one on my car too now. Though, the one I selected also shows tire temps. It's fairly accurate, though I noticed that the left ones don't show negative temp values anymore when it was cold out. Takes about 5-10 min to calibrate when you first start driving, handy to have. I only have the basic abs sensor tpms
@RL911
@RL911
Looks similar to mine, but it requires use of the 12v outlet. Mine is solar. I have two of them, one in my 18 and one in my 19. Both are still working very well. Only issue is on the 18, which is not garaged, the rubber boots are starting to deteriorate. On the 19, which is garaged, no issues.
Funny enough, yesterday morning I noticed that the sensors aren't working anymore. The screen lights up, but doesn't show temps or psi
